HELP!!!
e30-unit-soldier
Post Thu Jan 12, 2006 7:36 pm
I got a e30 325i 4 door g reg plastic bumper model.
Not been used for a month or two started it up today and left it running for about 2 hours (to charge battery up)then went to rev it and its not revving up!
When i push down the excellerator it feels like its about to cut out but it dosent! also if i hold down the pedal it dosent rev above 4000rpm! also if i hold down for a few seconds it starts to make a popping noise from the k&n filter a bit like a AK47 going off in Iraq!
Any help? I pesonally think it might just be the spark plugs but ill hold on till i get some feedback from some of you professionals!!! :cool:
OllieB
Post Thu Jan 12, 2006 7:44 pm
Blocked exhaust/cat maybe? I'm no expert but one of your silencer boxes might have collapsed inside, blocking the exhaust, causing said symptoms.
I'm too scared to drift properly......
x-works
Post Thu Jan 12, 2006 7:47 pm
Sorry for asking the obvious but is there much fuel in it?
Ant
Retired Team Member
Retired Team Member
Post Thu Jan 12, 2006 7:55 pm
Moisture in the dizzy cap !
remove, dry and refit, should sort it
fuel comment is very valid too
e30-unit-soldier
Post Thu Jan 12, 2006 10:40 pm
x-works wrote:Sorry for asking the obvious but is there much fuel in it?
Funny you say that the fuel light has come on but surely there would be enought fuel to last a short while!
Will give the dizzy cap a wipe tomz and see what happens thanks guys.
gcorky
Boost Junkie
Post Thu Jan 12, 2006 11:03 pm
ant wrote:Moisture in the dizzy cap !
ill second this :( moisure dispeller such as wd40
another possibility microswitch on throttle body......does it click when you move throttle arm????
Kos
Post Thu Jan 12, 2006 11:10 pm
dizzy cap and rotor arm
Mops
Post Fri Jan 13, 2006 4:06 am
um uh ???? sounds like she's backfiring.
is it getting enough fuel ?
all vacum lines ok?
line to FPR allright ?
1985/E30/325i coupe/5 speed/125k miles/shortshift/megasquirt II ECU controlling fuel and spark with custom ignitor and ICV mods/LC-1 wbo2/collecting parts for FI
Martinaston
Post Fri Jan 13, 2006 8:00 am
Sure there's not a squirrel nesting in the air box :mad:
There is NO nucleus.
