Have an E30 325i Sport and I started it today for the first time in a few weeks as I have it off the road at the minute, but I noticed today that there is no pressure in the clutch pedal making it hard to drive.
Anybody know what could be wrong with it?
Just my luck as it was to go back on the road on Friday lol
No pressure in clutch pedal? HELP
Grrrmachine
- E30 Zone Wiki / Team Member
First things first, pop the bonnet and check the clutch fluid reservoir. If it's low top it up, then press the pedal a few times. Get under the car and look for leaks. If you can't see any, then feel the carpet around the pedals.
Leaks underneath = slave cylinder
Wet carpet = master cylinder.
Checks as above, if that doesn't solve it more info can help with diagnosis. Does the clutch go to the floor and return (partially / slowly / not at all)? Can you engage gears under load? Is it just soft clutch feel but working ok?
