Check Control Panel
Just wondering can you fit the check control panel to cars that didn't have one factory fitted?
Cloggy Saint
a bit
, but would it be possible to keep the check control panel illuminated after the warning lights have all gone out? Or maybe wire it so it comes on with the lights? It would be nice to have a bit of illumination up top.
Kedge, no idea about your query, sorry!
Simon
- Contact:
Kedge, I would imagine it would be a huge job, but not impossible.
Datourer
Go here...
http://www.e30.de/
Go to the DIY section, interior, and there's a section there on keeping the panel permanently illuminated.
Datourer
Go here...
http://www.e30.de/
Cloggy Saint
Think i'll give it a miss then.
Cheers Simon
Cheers Simon
Cloggy Saint
Cloggy Saint
Cloggy Saint
I really want to do this but have hit a small snag. Are there 2 types of check control for E30s?? In the diagram on e30.de the multi-pin connector is shown having 28 pins, but mine only has 26. Is there anyone who's done this mod' who can steer me in the right direction?
Datourer
Go here...
http://www.e30.de/
Cloggy Saint
yeah that crossed my mind, but it looks as if the only thing disabling the seatbelt warning is the lack of bulbs! And as the article's on a german site i'm assuming it's a euro' panel (no seatbelt light). Hmm, i don't know whether to go ahead and scratch out the path to my pin 25 or to the pin 25 as depicted in the diagram.
Simon
- Contact:
Leave it if in doubt...cros or Brianmoore will probably answer this for you....datourer wrote:yeah that crossed my mind, but it looks as if the only thing disabling the seatbelt warning is the lack of bulbs! And as the article's on a german site i'm assuming it's a euro' panel (no seatbelt light). Hmm, i don't know whether to go ahead and scratch out the path to my pin 25 or to the pin 25 as depicted in the diagram.
Cloggy Saint
Cloggy Saint
Cloggy Saint
good question! if you use this link
http://translate.google.com/translate?u ... uage_tools
and click on DIY and then body/interior, and then the third article under the 'instruments' heading. It sounds very easy but the picture doesn't match what came out of my car!
Cloggy Saint
take off the plastic cover by prying the bottom out with a flat screwdriver. I removed the circuit board by putting a screwdriver into the empty bulb spaces on the left and carefully easing it out. The only point of connection is on the multi-pin plug so you can try pulling on that too.
Cloggy Saint
Cloggy Saint
sorry lads, i got the hump and had to go for a drive.... the missus didnt see the big deal so i had to leave before it all went "orange county chopper" in there
going tomorow to get a new cover,
thanks fpr the pic of the board, i stopped after it cracked,was too pissed to carry on.
will go at it again tomorow
Cloggy Saint
johnono, after trawling around some scrap yards, it does seem there are 2 types of check control panel. sealed units and ones that can be split. If you had trouble seperating yours it could be cos you have the sealed version. Anyway, i picked up a couple more and will experiment later. If i suss it i'll send you a spare as i feel sort of responsible for you breaking yours!
Cloggy Saint
Cloggy Saint
Cloggy Saint
Cloggy Saint
Easy datourer!
Thanks again for the screen (public appreciation post
so how did you clear the connection? did you scrape it out or use a solder iron on it, and was there anything to take off the board?
im giving it a go today anyway, and iԚ´ll be carefull this time
Cloggy Saint
