What offset do I need? E36 M3 Hub Setup
Rickz
Post Sun Feb 01, 2015 8:59 pm
Hi guys,
Wondering if you can help at all?
My cab came with a 5 stud conversion which a E36 M3 Evo setup at the front and I'm pretty sure the rear have E36 Compact Rear Swing Arms.
I have E36 M3 Brake setup all round too.
Now the question is, I am going for some Hartge Rims but not too sure what offset I need?
It is a m3 rep convertible but I want the weels to sit flush with the arch. Under no circumstances do I want the wheels to stick out?
Will I get away with ET25 all round??
I thought if I go 8.5j on the front and 9.5j on the rear, I could always play around with spacers to get the perfect fitment.
Rickz
Post Mon Feb 02, 2015 6:06 pm
Anybody???
Bump :D
Motorhole
Post Mon Feb 02, 2015 8:11 pm
I know from experience 8j at et29 sits a tad proud. Only slightly mind. What size are your rims? If they are 16”a you will also need to consider brake caliper clearance. If they are 15s they eont fit at all. I'm on 16's now, et47 x 7j but need 15mm spacers to clear the brakes. So effectively et32. They sit perfectly.
Rickz
Post Tue Feb 03, 2015 8:03 pm
I'm going for 17s!
Grzesiek325i
Post Thu Feb 05, 2015 12:49 am
In my setup i did't measure it but people say its about +20mm per wheel. So its ET+20 comparing to stock E30
