I've got a problem with my 325i not starting.
I had some rust on the bulkhead by the loom grommet, so I removed the loom from the car. Sadly, the POS 1990's immobiliser/alarm/RCL was too big to fit through the hole, so I had to cut it out of the loom. (I just cut all the wires leading into the box.)
The time has come to rebuild the car, starting with the wiring/engine. I've got it all bolted back together, and tried to start it today, but nothing happened - just an alarm siren started (which I think is a different siren to the one I removed? Been so long since I heard it though, I couldn't say for sure), no starter motor or anything. Before my butchery, it would start, and then cut out if the immo wasn't happy.
So, I guess I have two questions really. Firstly, there's this box under the bonnet - I've seen one other E30 with the same box in the same position. Is this an OEM/factory option thing, or is this more of the aftermarket crap?
(Ignore the mess!)
Secondly, what wiring is needed for the car to start? So far, I've connected the engine loom/ECU, the battery, and the three plugs from the steering column to the main wiring loom (I'm guessing these are mostly for wipers/lights though, but I guess the starter motor/ignition wiring is in this), and the round plug by the fuse box, but that's it.
I'm guessing this is going to be a case of tracing the wiring of that old alarm system, but I'd like to know what I'm working with before I go too far with it all.
Thanks for any help!
Joe
