e30 cabriolet central locking red/black mod
viz007
Post Sat Jan 24, 2015 8:34 am
Hi All
I know this topic has been covered extensively but I wanted to clarify something before carrying out the modification and do it wrong!
The wiki says that there are 3 wires to join in the cabriolet models. From what I can see:
1 wire leads straight to door plug
2nd wire leads to CLU
I undertand these are the 2 that would be normally joined as described.
The 3rd wire appears to go from the CLU into the door plug.
So do I join wire 1 and 2 as normal and the 3rd joins from the CLU to the join made above? IE neither red/black connections remain from the door plug.
**BANNED**
Post Sat Jan 24, 2015 8:54 am
viz007 wrote:Hi All
Correct.
My original wiki article made it clear that the aim was to eliminate the red/black looping through the door/A pillar plug/socket,unfortunately this part was 'edited' out!
This connector is known to corrode,a proccess encouraged by a permenant live feed passing through it.The red/black wire only enters the driver's door to feed the (optional) heated door lock,a feature that is very rare on UK spec E30's,so can be removed without any other issues.
viz007
Post Sat Jan 24, 2015 9:29 am
Thank you for your fast response. I'll give it a go this weekend!
Post Sat Jan 24, 2015 10:35 am
One red/black comes out of a small loom that runs along the sill from the back of the car, another goes to the locking ECU socket, and the third goes to the smaller socket for an interior light delay relay (which probably isn't fitted on your car).
Cut all three of these wires away from the socket in the A pillar by reaching through the hole for the loudspeaker, solder them together, and insulate. None of them should be left connected to the A pillar socket.
There is also a red/brown wire that goes to the socket - don't mistake this for red/black.
viz007
Post Sun Jan 25, 2015 5:22 pm
I haven't done the mod yet but managed to fix the central locking by resoldering a component on the circuit board of the CLCU. I will still be doing the mod another day.
Post Sun Jan 25, 2015 8:21 pm
I hope that this resoldering didn't involve the addition of any fresh solder (assuming you're talking about the thermal cut out spring.) This was originally soldered with a special very low melting point solder, to form an important safety device.
If you've added conventional solder, especially that useless modern lead free stuff, then the ECU needs to be replaced. The fuse for the central locking provides short circuit protection only, not the more important overload protection.
viz007
Post Sun Jan 25, 2015 9:25 pm
Thanks for this. I have seen various low melting point solder available to buy. Do you know whether it is ok to use something like this or am I just better off replacing the central locking unit.
Post Sun Jan 25, 2015 10:10 pm
The problem is that we don't know what particular solder was used to be able to repair the spring and retain its effectiveness.
The heat generated by the resistor should be minimal in normal use, so I'd go for about the lowest melting point stuff you can find. 130 degree at the absolute highest, and preferably lower.
viz007
Post Mon Jan 26, 2015 3:42 am
The low temp solder is quite expensive so I managed to find a replacement unit online for less. Thanks for your help
