i have just measured my front anti roll bar its 18.5mm
where is the best place to get these in polybush?
also best way to re fit them?
front ARB poly bushes
- Contact:
It will be 19mm
These are good http://www.ebay.co.uk/itm/19mm-BMW-E30- ... 3a9d02ab06
Bought 19mm ones
Cannot fit these for love nor money
New shackles and old shackles both do the same thing
The front peice of the shackle keeps popping out the slot not going far enough in to allow it to come up to the bolt hole
Closest I've got the bolt hole to line up is 2 cm gap
Any one able to help? Really got the hump with it tonight
- **BANNED**
1 Swear,a lot...let next door's kid's learn a few new words..
2 Place a jack under the clamp and lift as far as it will go without popping out.
3 At this point,use a longer bolt to pull the clamp closed.
4 Hold the clamp closed with a pair of mole grips and swap the bolt for the correct one.
5 Grab a beer from the fridge to celibrate!
Youth is wasted on the young.
You two are legends all done now front wheels on the deck for the first time in 14 months!
Also next door may have learnt a few swear words! I think I taught myself done new ones when my brother did the other side to what I did first time! Fuming!
