Removing E30 Inlet Manifold
MPOWERCRAZY
Post Tue Dec 16, 2014 5:19 pm
Hi all,
Wanted to remove my inlet manifold on my 325i cabby, anything to be aware of once removing? some step by step guide would be great!
Thanks!
Lurch320i
Post Tue Dec 16, 2014 6:23 pm
There's an oil breather tube under the inlet manifold connecting the crankcase to the inlet
It has a spring on the bottom so you need to push that tube down as the manifold slides off the studs
Obv disconnect the fuel rail and the Injector loom underneath the mani
Post Tue Dec 16, 2014 7:57 pm
Breather pipe needs two new and well lubricated O rings when refitting.
There's a bit of a clearance issue getting the manifold past the water/thermostat outlet elbow, but it can usually be wriggled by.
