Thankfully I managed to get it going again but it conked out just as I was coming up to a very busy crossroads, luckily the lights changed and I had enough momentum to get me most of the way across before I had to leap out and push it out of the way.
I'm guessing it's fuel related as the symptoms were very similar to running out of fuel - I.e no warning in the way of dash lights I only realised it was dead when pressing the throttle had no effect.
On trying to restart it would fire for a split second and then die again - did this 7 or 8 times. Then when it did fire it ran very lumpy for around 30 seconds and then the idel returned to normal and it was fine to drive home.
Whilst it was running rough I popped the bonnet but couldn't see anything amiss, no smell of fuel leaking, battery terminals tight, nothing arcing.
Is this likely to be a failing fuel pump ? Do they stick ? Fuel pump relay ? Crank sensor ?
On an 88 325i is there an in tank pump or is it external or both ?
Be grateful of some advice as to what I should check first and how to check it.
Car got me home ok and is now back in its garage I was nervous driving it back though.
