Bleeding The Tappets
ad318i
does anyone know how to bleed the tappets?
thanks
thanks
Wid77
I am no expert but i don't think the tappets can be bled. Do you mean adjust the tappets?
ad318i
my flatmate said could be but hes most likely wrong lol........
its to stop that stupid clicking noise!
Geoff
Yeah they need readjusting with a feeler guage to set the correct tolerances. Bentley manual will tell you all you need to do. Not too compicated from memory.
smithy318i
Everything above is WRONG...
M40 Engine has hydraulic tappets, which cant be manually adjusted.
However i have heard somewhere on the zone, that you CAN bleed them.
IIRC it involved drilling a hole in them, then soaking them in degreaser or something...
Im off to do a search...
gcorky
- Boost Junkie
m40 i.e 1.6 and 1.8 8v are hydraulic and tapping here is cam ,follower wear that needs rebuild.
m20 i.e 2.0 and 2.5 are adjustable eccentric covered in tech guide.
Martinaston
You can bodge them by crushing them in a vice (without damaging the head) to loosen the sludge inside thats solidified around the spring, but to get them out the cam and timing belt have to come off.
There is NO nucleus.
ad318i
sounds a bit of an effort then..... may take me a while to do it then!!
thanx everyone
thanx everyone
gcorky
- Boost Junkie
going to this trouble i would just fit new ones but more than likely need cam and followers to cure properly!check spray bar too as they do clog if vehicle has exeeded oil change intervals and or cheapo fence painting type oil....lol
oguz327
- Captain Armco
is it a very big/expensive job to have tappets adjusting?
my mechanic said last time i took the car in they needed doing although engine runs sweet at the moment,
ive also read on one thread that this can make a difference in performance?
m3ben05
KiNaKa
Mind to post more about this info ?smithy318i wrote:Everything above is WRONG...
Thanks in advance...
Daniel
May i know WHat model are you driving ??ad318i wrote:sounds a bit of an effort then..... may take me a while to do it then!!
thanx everyone
M40 basically u can't adjust because of hydraulic tappets
M20 you can adjust by yourself
-remove the valve cover
- you can choose to remove spark plug or not its up to you, due to the efforts to turn the crankshaft pulley when compression stroke..
-remove the fan clutch (optional) you still can adjust the crank pulley if your hand can go in, or you can adjust the pulley from bottom.
- Set both intake & exhaust valve for the cylinder in close position which means either (compression stroke) or (end of exhaust stroke) so that the camlobe are totall free from the valve lifter for both Intake & Exhaust side..
- Use common ring 10mm to loosen the valve lifter nut, use a metal wires around 3mm to adjust the small hole on the valve lifter, at the same time measure the valve clearance by using feeler gauge...
i've set occording to haynes manual but the gap is too big and cause the noise.. so i set mine to 0.10mm intake, 0.12 exhaust, it still can be lower if u feel the noise is occurred BADLY i mean...
apply the same method to all other cylinders..
Install everything back in reverse order..
hope this help...
ad318i
its an M40! so dont think ill have 2 much luck
KiNaKa
too bad but i'm glad to see if ad318i can post up the information that he intro before this...
E30Mark
M40's tap tap tap all day long, chances are the cam is worn...
On my old engine (M42) in my 318iS it had hydraulic tappets, on cold mornings one of them started to tap real bad, i used a can of Wynns oil additive from Halfords that was meant to quieten tappets, and it did! To say i was amazed at this stuff working was an understatement!!!
Basically the tappets fill with oil, which over time sludges up, i guess this additive breaks down the sludge and allowed new oil in. Since then I've fitted another engine anyway, so can't say if it is a long term solution...
Adjusting tappets on a M3 (S14) is another story, you change the shims to acquire the correct gap, and you need a proper tool to do it!
PM for details
PM for details
