Split Rubber Fuel Hose OEM Part#
Shane_M
Post Wed Dec 10, 2014 3:34 am
Hi all,
I am looking for a part number or compatible part to replace a perished fuel line. The photo below accurately shows the location of the line. It is underneath the inlet manifold;
As you can see by the fuel dampened area which hose I refer to. This is on the left (RHD passenger side) of the car.
What is the length of the hose, diameter etc. I am interstate and can't simply pop out and have a look, I need to order the part so it can be replaced. On www.realoem.com I can find the junction that is plugs into (part# 13311709577). Is it the 8x13mm (part# 16121180409) hose from the fuel filter/fuel strainer?
But I just can't find the part for this hose or even any diagrams that show this hose. If anyone can tell me, then it would save me a heap of time and hassle.
Cheers all.
Shane
Shane_M
Post Wed Dec 10, 2014 10:32 pm
So I think I found the part. I ordered part# 16121180409 a Fuel Hose 8mm x 1m. I am pretty confident it's the one to replace the perished and split one.
Next year, I plan on replacing all rubber hoses with braided hoses and radiator/cooling hoses with silicon, then they should last quite a bit longer and stay in much better condition.
Post Thu Dec 11, 2014 6:56 pm
You don't need to buy it from the dealer. All you need is unleaded specific fuel house with an 8mm internal diameter you can probably get a decent length from ebay and then cut it to the size you need
Shane_M
Post Thu Dec 11, 2014 9:27 pm
Thanks Rob,
I was a bit pressed for time, as the mechanic starts on Monday, so to be safe, I just ordered this with express postage. It arrives today. The other one will need replacing too, so I'll do the other one with an aftermarket hose.
Shane
