I'm planning to swap a M52B28 in my '84 E30 320i , but I have 45mm struts in combination with KW coilovers,
Is it a bad idea to have 45mm struts instead of 51mm with such a big engine? I guess not, but I wanted to be sure..
Thanks.
45mm struts
age
- Formerly twist316
no it will be just fine
M40 rightness if you can get to 6000rpm noone can hear your tappets
HairyScreech
The whole point of the 51mm strut is it allowed a larger more effective damper.
45mm struts are just fine strength wise.
