Map Light Bulbs, e46 rack spacers and chrome trim questions
ashje
Post Tue Dec 02, 2014 11:09 pm
So firstly i've installed the map light mirror and the lights seam a tad dim, what type of bulbs are they and can i upgrade to the LED type?
Secondly i've installed my e46 rack with the rack spacers above the rack, has anyone tried putting them below without issues? Reason being i'm running low with a custom sump and the rack is now the lowest point.
Lastly the chrome trim which goes around the side window has popped off at the front and it won't clip back on, do they require clips? If so what P/N?
HairyScreech
Post Wed Dec 03, 2014 12:39 pm
You can put the rack to the top if you have enough clearance, seems to work fine.
ashje
Post Wed Dec 03, 2014 12:59 pm
excellent, i was going to have a crack anyway. There does seam to be enough, if not i'll put spacers above and below at least it will help.
