Over fueling
lowdub
Post Tue Dec 02, 2014 10:55 pm
When to see a friend to check out my car with a bad misfire he checked my spark plugs and said it is over fuelling. And need adjustments
Any fuels ?
Post Wed Dec 03, 2014 12:27 am
IT DOES NOT NEED ADJUSTMENT! Unless someone has already been 'adjusting' things, in which case, these need to be returned to the factory settings.
You have one or more faults, which need sorting. When that is done, the misfire will be gone and it will not be over fuelling, with all the adjustments as they were set at the factory.
Can't help any further at the moment, since you've given us no clue as to what model and age of E30 you have, but testing the engine coolant (blue) sensor AT THE ECU PLUG will probably be the first move.
