getting a windscreen out
xavier
I have a bought a windscreen from a wreck, only problem is that it is still in the wreck. Is there an easy way to get it out? I thought about cutting the old rubber seal off with a Stanley knife.
- E30 Zone Meets/Events Team
There should be either a chrome or black trim in the windscreen rubber.
You need to remove this, and then push the winscreen out from inside the car from the top left or right corner.
Shouldn't take more than 10 minutes to take it out.
BenHar
Pull out the rim that fits into the middle of the rubber all the way round.
Loosen the rubber away from the screen with a plastic knife or similar.
Gently push one of the tuop corners from the inside.
It should come out easily.
Ben
Ben
xavier
thanks for the info. like you said it took just 10 minutes.
