320i '85' L jetronic problems injection
vercruysse30
Post Wed Nov 26, 2014 10:19 am
I have a 320i L Jetronic 1985
he does not want to start the six injectors are not activated
what could be the problem :?
Andyboy
Alpina Colada
Post Wed Nov 26, 2014 5:10 pm
Fuel pump relay, common problem on the old LE Jet systems. It's a tall black relay near the air filter box and has seven pins and whilst it's called a fuel pump relay, it also activates the injectors.
Post Wed Nov 26, 2014 6:53 pm
Is this the engine that's been transplanted into a facelift shell? If so, the problem could be with the signal that operates the relay, rather than the relay itself. The green (switched ignition live) wire to this relay arrived by the C104 plug and socket, which won't be present in the facelift body loom.
vercruysse30
Post Thu Nov 27, 2014 12:05 pm
yes I have ignition and not only the injectors the injector is also koudstart how can I check or do :?
