318is rad cap.....
BHadley
Post Sun Nov 23, 2014 10:43 pm
Hi,
Have seen on here that a e30 318is m42 etc... Should have a 2.0 bar radiator cap whilst others under recall had 1.4 bar cap.
Reason I ask is the yellow disc in the base states 140, do I have the right cap and what issues could it cause? Rad was changed in 2002 according to the history
Any idea?
Thanks....
Post Sun Nov 23, 2014 11:38 pm
You have the wrong cap, which will lower the boiling point of your coolant by about 10 degrees.
I doubt if this will cause any problems in normal use.
minesapint
Post Sun Nov 23, 2014 11:45 pm
Read this http://www.e30zone.net/e30zonewiki/inde ... g#Tank_Cap
Looks as though you may have the wrong one.
BHadley
Post Sat Nov 29, 2014 10:14 am
Thanks for replies.
if its not going to effect anything I'll leave it be...
Usefull to know all the same
Cheers .....
