steering fluid leak
Cloggy Saint
scallyally
16mm and 14mm (2 per bolt- bolts are different sizes)
Cloggy Saint
scallyally
Yes, and remember they are 'crush' washers, I.e soft aluminium.
scallyally
Cloggy Saint
scallyally
They will be fine
Cloggy Saint
scallyally
mmm, strange, check the mating faces that the washers sit against for scores/burrs particularly under the head of the bolt.
Grrrmachine
- E30 Zone Wiki / Team Member
I've got a similar leak that I've been meaning to fix for ages. Someone recommended Dowty seals, but I can't seem to find any over here
BHadley
Mine leaked a slight drip after a power steering change.
I changed the larger crush washers for copper and found the right torque setting of 40nm (
that's the 22mm banjo nut)
scallyally
Dowty washers with a nitrile inside seal are a last resort (e-bay) not cheap at over £2.00 each.
BHadley
If your going down the dowty route it must be cheaper from a hydrolic hose place like pirtek for example ?
Cloggy Saint
BHadley
Its a metal sealing washer with a nitrate center ( internal rubber ring in the center) used on high pressure hoses like commercial steam cleaners and hydrolic power packs for things like jack hammers that rip up roads ...... Take a lot of beating,
scallyally
Just Google Dowty washers, all will be revealed. P.S you must have got through some fluid!
Cloggy Saint
