Guys is the fuel pump relay the same across all models?
My 320i 1990, just has a Bosch relay with no part number..
All the part numbers for the fuel pump relay listed in the wiki here, are not coming up on Real OEM under my car.
http://www.e30zone.net/e30zonewiki/index.php/Relays
Fuel Pump Relay
Mitchen
Mitchen
Any ideas anyone?
Pump relay is just a bog standard 4 pin 30A relay - just needs to have the pins in the correct places. Only thing special about it is that it has retaining lugs on the case to ensure it stays in place.
IIRC., the wiki numbers don't match up with anything I've seen, either.
Mitchen
Great thanks Brian
