Diff internals
heathy325
Dose anyone know if the internals from an e39 ie the crown wheel and pinion will fit in the e30 med casing as these are a lot cheeper than the e36 ones as I'm after either a 3.07 or 3.15 for my m52 conversion
age
- Formerly twist316
no they wont unfortunately, e34 ones fit if thats any help
M40 rightness if you can get to 6000rpm noone can hear your tappets
heathy325
Nice one thanks anyone run the m52 conversion with the 328i box and a 2.93 diff??? If so what are the thoughts as this is the one I have to put in, also what is the ideal one for normal road use?
heathy325
Do e34 internals fit the e30?
heathy325
Cheers I've done diff rebuilds before, will need some new crush rings and that though so will give him a shout
