Pointless Heater Valve Solenoid
Dweed144
Post Tue Nov 11, 2014 4:42 pm
Hi All.
I recently had a coolant leak from the heater valve. First I just diverted the pipes in the engine bay, but then I decided I needed the hot air to dry out the passenger footwell. I bodged it by making a blanking plate over where the solenoid mounted and reinstalled it.
I assumed that it would give me only hot air, but it turns out I still have full control over the temperature of the air.
So what is the point in the solenoid?
Post Tue Nov 11, 2014 6:35 pm
To give fully cold air. Without the valve, the air from the vents will be slightly warmed on the coolest setting.
I have the valve disabled on one of mine. It has a LPG vaporiser connected in series with the heater, so I need flow through the pipes all of the time. The heating of the air is small, but noticeable.
