Hi,
Behind the bulk head cover on the passenger side (Behind coolant tank) of my M3 I came accross 3 relays.
Does anyone know what the 3 relays are used for?
M3 Relays??
jpboost
the large square black relay nearest the passenger wing is the evaporative purge realy. (mine doesn't have htis as it's a very early one)
One of the others is the main power relay, which does all the igntion live in the fuse box etc.
Can't remember the other one.
Have a search about on s14.net, you should find what you need there.
monsport
I was thinkin because mine is an early m3 aswell and that black relay is missing on mine also but the wires are connected underneath. its not blanked off.
jpboost
mines exactly the same,
but My fuel filter is located where the evaporative purge stuff (charcoal canister etc) normally sits. So I presume it's not meant to have it!
Demlotcrew
IF the car is non cat then it doesnt have the purge valve.
Andrew
Andrew
jpboost
that makes sense.
Mine's a non cat '86 car.
monsport
Mines the same as yours so that solves that problem cheers lads
