I have a 1989 Cecotto and I'm having issues starting it. On three occasions now I have had this happen when it seems the fuel pump is failing. Its intimating so I have replaced the 2 pumps and filter but that has not resolved the issue. So after a bit of further internet research the relay may need attention, the question is where is it? I have found various web pages suggesting its under the cover on the bulk head but not on mine... can anybody help?
1989 E30 Cecotto Starting
Demlotcrew
The S14 engine relays are on the passenger side behind the coolant expansion tank, there are three of them, once you take the black cover off you will see them. I can't remember from memory which one is which, but one is for the ECU, another for Fuel pump and the last one is for the Lambda sensor.
