I have a 318i and have bought a pair of front struts from a 325i with the larger diameter shock and better callipers/discs.
In the long run, I plan to do an engine conversion, but not for a while.
Do I need to replace the front springs for ones suitable for my lighter 318 engine or will these be OK?
I have recently done the rear disc conversion and my rear end is 30mm lower that the front. These front struts are lower and will sort that out, but I wonder if they will cause handling issues due to their higher spring rate.
Any ideas? Thanks,
