LSD ratio help
E30LI
Post Thu Sep 25, 2014 12:50 pm
Hi guys,
Bit of a novice when it comes to LSD's and understanding the ratios. Just wondered if anyone could help me figure out the best ones to look out for.
My E30 is running a Nissan SR20DET engine, pushing about 260bhp, with an aim to hit around 330bhp by the end of the year.
The LSD i've seen up for sale is one from a 325is and is 3.73. Would that be suitable? I'm not looking to use the car for drift, i'm after more usable road power and like to take it up the strip on drag days etc.
I'm still currently running the 316 standard diff so need to sort an LSD out before I chase more power.
Thanks for any help guys,
Oli :)
HairyScreech
Post Thu Sep 25, 2014 1:10 pm
I think the big question here is what gearbox you are running?
E30LI
Post Thu Sep 25, 2014 1:16 pm
Hi there, it's a standard 200sx s14a gearbox!
Motorhole
Post Thu Sep 25, 2014 5:43 pm
I found the following ratios online for the 200sx box - although not sure of the reliability of the source:
1st: 3.321
2nd: 1.902
3rd: 1.308
4th: 1.000
5th: 0.759
Reverse : 3.382
From the same source, factory final drive was 3.692 - so that would suggest a 3.64 or 3.73 BMW diff would be ideal. However it does also depend on wheel/tyre size. According to a handy spreadsheet I've built, with those ratios and with 215/45/16 tyres, you'll easily be making 60mph with just 1 gearchange and doing 70mph in 5th at about 2900 rpm, assuming a 3.73 diff. That's about right for a daily driver with the power you're talking about, but you might want something a bit taller (3.91?) for track work.
HairyScreech
Post Thu Sep 25, 2014 6:06 pm
That all seems about right ratio wise.
Just go for a medium case 3.73 then.
maxfield
Post Thu Sep 25, 2014 7:42 pm
I've driven a couple of S14s and always thought they were very long geared.
I'd be tempted with a 3.91.
Motorhole
Post Thu Sep 25, 2014 8:35 pm
You will deffo want something shorter if you're running 45 profile 17s or bigger too.
E30LI
Post Fri Sep 26, 2014 11:30 pm
Thanks for all the replies, that helps massively. Going to look at a 3.73 this weekend so will give that a try and see how I get on with it, as it's mostly road use that it'll be getting used for, but will try a 3.91 if i'm not happy with it.
Thanks again! :)
DCe30325i
Post Fri Oct 10, 2014 11:04 am
Hello Peeps,
Please can you give me some advice on the best LSD to use on a 325i E30 (1989) switchable auto Gearbox.
Could I use an LSD from an auto Z3 or E36?????
Superleggera
Post Sun Nov 16, 2014 8:27 pm
Hi Oli
Any chance I can have a chat with you ? I'm looking at doing a sr20det swap and had some questions and for some reason my PM to you doesn't send. If so please PM me back.
