Notchy clutch engagement slip/grip
Z2TT
Post Tue Sep 09, 2014 4:45 pm
Hi.
I'm wondering what could cause this, it happens during lower revs not giving it much gas when letting off the clutch. It will grip then do like a yoyo type of thing, lurch a bit, stop then lurch a bit more then get going normally, feels like it slips/grips and then it drives fine. It's hard to explain in words. Under all other conditions it doesn't appear to slip or give any issues, just the engagement is notchy on low throttle unless your getting off the clutch very slowly.
Normally if you give it more revs and get off the clutch smoother it wont do it.
Just wondering could a worn clutch cause this or air in the lines, or pressure plate issues?
Thanks.
HairyScreech
Post Tue Sep 09, 2014 5:04 pm
Some times its the IVC trying to prevent the engine stalling.
jmc330i
Post Tue Sep 09, 2014 8:03 pm
Standard E30 or one with an engine swap?
James
'91 325i Sport
'93 318i touring 16v
Z2TT
Post Wed Sep 10, 2014 5:33 pm
Standard E30 325i Motronic.
