does m50 bearing shells set is same with m20 bearing shells set?
thank you
markus
need info on m20 bearing shells set
markus_74
reggid
probably rod shells only. there are two different sets of m20 main shells. single or double tang depending on the year of the block
should be able to check realoem or a supplier website for the definitive answer
E30 325is with M20B31
markus_74
hello, reggidreggid wrote:probably rod shells only. there are two different sets of m20 main shells. single or double tang depending on the year of the block
this info is valuable for as I don't know before that the shell is single or double tang.
my block is from e34 520i 1989 is it use single or double tang?
thank you
markus
HairyScreech
Just to add, the single tang will work in all block iirc.
markus_74
thank you hairyscreech, can you please info me with part number for standart
markus_74
this engine block is taken from e34 520i what I don't know what year is it, any one can help me to info me?
1288322.c and 2A 89 this is stamped into the engine block.
is it use 1 or 2 tang?
and
how to open this dipstick hole, as it is look very solid and can not open, or should I use the dipstick hole in the oil sump?
HairyScreech
What does that dipstick hole look like from below?
markus_74
is it a small hole also same diameter with the top hole.HairyScreech wrote:What does that dipstick hole look like from below?
markus_74
this is the dipstick hole from below? can I use it? may be hit it with hammer to open bung?HairyScreech wrote:What does that dipstick hole look like from below?
I have oil pan from e34 m20 engine should I use this?
