Getting a ticking noise from the glove box area that starts around 1.5k and gets faster with revs then disappears after about 3k.
Any ideas?
Ticking noise from glovebox
jmc330i
Is this an engine converted car? An M60 cab springs to mind??
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Laith
Yes it is an m60 cab. Only really started since the conversion.
jmc330i
Exactly what I thought.Laith wrote:Only really started since the conversion.
I'd suspect the heater valve is ticking as you've got the heater pipes on the wrong way round. I'm not sure on the M60 (can't see it being different), but usually the pipe from the back of the head goes to the lower heater pipe on the bulkhead.
Having the pipes the wrong way round can damage the heater valve as you're trying to force coolant through it the wrong way.
James
'91 325i Sport
'91 325i Sport
Laith
Oh bollocks. Sounds like an ASAP job. Do you know of any pictures/diagrams? Cheers for the help mate, I was thinking it was just a relay clicking away but the correlation to the rpm didn't make sense.
Laith
Pretty sure your right - realised I have no heat when the car is moving fast.
jmc330i
No heat at higher revs is sure fire sign.
I don't know of any pics to hand and I'm at work at the mo, but if you look at the bulkhead on the passenger side (assuming its RHD) you should see two pipes heading through to the heater. These will need swapping top to bottom. You may loose some coolant so you might need to bleed it after.
I've not not had many dealings with M60 conversions, but I'm guessing it will be tight for space at the back of the left head??
James
'91 325i Sport
'91 325i Sport
