Hi,
I am changing all metal brake and fuel pipes quite soon (fuel tank out as its easier so I'm told)
So I can start getting parts together;
What unions would I need for all the fuel and brake joins.?
Can the 3/16 kunifer brake pipe be used for fuel lines too?
I have found a good supplier of pipe and flaring tool (not the cheap puller type)
And are the brake spring clips single use items ?
Car is 1991 with rear discs and no ABS set up.
Ta....
Brake and fuel line renewal Info please
BHadley
blazed
i got this tool not so long ago works well with kunifer.
http://www.ebay.co.uk/itm/Brake-Pipe-Fl ... 3631&rt=nc
u will prob need new flexi hoses as they will round off when.
GSF and EURO car parts sell fuel line.
BHadley
Thanks, yeah that's the tool I've got on watch!
I meant can the brake pipe kunifer be used for the petrol tank hard lines as well.
Just a bit unsure of what unions I need now, flexi pipes do look past their best so good shout!
