Re-furb my BBS wheels
M3Tony
Post Fri Jan 06, 2006 3:22 pm
I have a 320i cab with BBS 16 inch and Goodyear Eagle F1 tyres 205/55/15.
Wheels need refurbishing, as look tired - no heavy damage, just 16 years & 79k miles.
What is best approach to do this ? How much should it cost ? Can I get easily the centre plastic caps with BMW logos, to finish off the job nicely ?
Garages in Reading/Oxford area ?
My 12 year son swears i can get a set of new ones for Ԛ£150...which is probably less than the refurb. Any clues appreciated.
m3ben05
Post Fri Jan 06, 2006 3:38 pm
are they standard BBS or split rims? If thet are standard you should be able to get them done for around Ԛ£40 per wheel.
try wicked wheels http://www.wickedwheels.co.uk/Locations.htm
Steviec
Post Fri Jan 06, 2006 3:41 pm
OFG320i wrote:I have a 320i cab with BBS 16 inch and Goodyear Eagle F1 tyres 205/55/15.
How do you get 15" tyres on 16" wheels? winkeye
M3Tony
Post Fri Jan 06, 2006 3:45 pm
Thanks for quick reply. They are 'standard'...single piece alloy wheels, so I guess not split rims. I've emailed Wicked Wheels for contact, etc. Any idea about the centre caps that also look tired ?
M3Tony
Post Fri Jan 06, 2006 3:47 pm
Good question....I just measured the diameter of the alloy wheel....and it was 16" - is this wrong approach ? Tyres say 205/55/15 on them.
E30Mark
Post Fri Jan 06, 2006 3:52 pm
OFG320i wrote:Thanks for quick reply. They are 'standard'...single piece alloy wheels, so I guess not split rims. I've emailed Wicked Wheels for contact, etc. Any idea about the centre caps that also look tired ?
Get the caps refurbed at the same time, they cost about Ԛ£25 each from the dealer.
Lepsons in Gillingham, Kent do a truly superb job at Ԛ£50/wheel.
PM for details
gcorky
Boost Junkie
Post Fri Jan 06, 2006 4:07 pm
50 pound to do these ,seems going rate.[/url]
charlE30
Post Fri Jan 06, 2006 7:04 pm
OFG320i wrote:Good question....I just measured the diameter of the alloy wheel....and it was 16" - is this wrong approach ? Tyres say 205/55/15 on them.
If the tyres have 205/55/15 then they are 15" :lol:
It would cost a lot more than that per wheel for new BBS, it will be cheaper to get em refurbed
BMW F31 335d xdrive
GDBN
Post Sat Jan 07, 2006 4:38 pm
Over here a new 15" BBS costs roughly Ԛ£135 each. Without centre cap.
G
