325 Vibration - SORTED now :)
E30-Addict
Post Thu Aug 14, 2014 12:43 pm
Hello Everyone
Took the 325i for a track day and a bit of drifting session
The car developed a vibration underneat when accelerating
Turned out to be the prop centre bearing snapped. Changed that and while I was there swapped the diff with another good one with a decent bush.
Vibration can be still felt coming from the drive train in all gears.
I am suspecting
1- gearbox mounts
2- prop shaft rubber donut
3- actual prop shaft needs balancing
Am I going on the right direction or is there other common issues on e30 m20 vibrations ? :roll: :roll:
Much Appreciated :) :)
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming
HairyScreech
Post Thu Aug 14, 2014 12:58 pm
without the centre bearing the guibo (rubber doughnut) will be shagged.
E30-Addict
Post Fri Aug 15, 2014 12:52 am
Turned out to be gearbox mounts and guibo were shagged
Thanks Pal
Just finished it and its all sweet and dead quiet (apart from the welded diff)
