m20b20 Big end shells
SGP
Post Sat Aug 09, 2014 5:08 pm
Hi. realoem.com list 3 different colours for the above ; green yellow and white, each colour is availabe in three sizes. My big end bearings need replacing and I'm wondering which colour to order.
Thanks.
If it ain't broke..
Fix it till it is :)
sweep
Post Sat Aug 09, 2014 5:17 pm
has your crank ever been re-ground? you may need to have it mike'd up at a machine shop-colours indicate sizes.
SGP
Post Sat Aug 09, 2014 6:05 pm
Each colour is available in three sizes. Each size is available in three colours.
If it ain't broke..
Post Sun Aug 10, 2014 11:39 am
yes, so as Pete says get the crank measured or use plasti guage to see what it needs
SGP
Post Sun Aug 10, 2014 1:43 pm
Maybe I'm not making myself clear.
Each size is available in 3 colours.
If it ain't broke..
Post Sun Aug 10, 2014 3:11 pm
As Simon says, you have to trial fit a new bearing shell and use plastigauge to see if it's the right one. Engine building, done properly, involves a lot of putting together and taking apart. Six steps forward; five steps back.
If the crank is being machined, ask the machine shop to select and supply the bearings for you.
SGP
Post Sun Aug 10, 2014 4:41 pm
Thanks for the input guys. The condition of the crank is fine. i'm using the small shells; blue for the top and red on the bottom..
I have made an error in my original comment, it relates to the crank bearings not the big ends.(sorry)
These are available in the three colours aforementioned.
I will be needing the small (thin) ones ie. 60mm (0). There are three part no.s for this size in the three colours. is it the case that these are different sizes that are too small to declare ?
If it ain't broke..
SGP
Post Sun Aug 10, 2014 10:32 pm
If it ain't broke..
SGP
Post Tue Aug 12, 2014 5:05 pm
On closer inspection, paint spots have been left by the factory. Moving over to the M20 sub-forum with pics.
If it ain't broke..
