whats the best brakes to fit to a 325i sport
h2ggv
Post Thu Aug 07, 2014 8:24 pm
after driving the car for a hour or so noticed the brakes are fading after about 30 min. i drive it hard when i use it.
Whats the best set up for disc and pads dont want to be going mental and fitting different brakes off other cars just a simple disc and pad change whats the best to buy that you have tried and tested.
Any links would be great
Thanks again
BHadley
Post Thu Aug 07, 2014 11:31 pm
What's the brake fluid like? If its black or age unknown change it and the brakes will not fade so soon...
DOT 4 seems good for all round use, maybe dot 5 for track and ultra sprites driving but would need changing more often as it absorbs water a lot faster than DOT 4 brake fluid.
A good cheap starting point and a good Maintaince/ safety item sorted too!
