Post
Sat Aug 02, 2014 9:22 pm
The valve does NOT adjust the temperature of the heaters output, in spite of what it says in Everet's book, except in the 0.001% of E30s that were fitted with climate control.
The valve is closed when the temp. dial is at full cold, but when the dial is moved a few degrees off of its stop, a switch closes, which applies 12 volts to the valve, which opens fully and stays open for the entire rest of the temp. control's range.
The valve's purpose is to ensure that on the full cold setting, there is absolutely no heat emitted from the heater.
You can get enough access to see what's happening simply by removing the inspection panel above the glove box, followed by the one to the right, but the rear and centre consoles have to come off to change the valve.
The only fixing that's difficult to undo is the small self tapper that's hidden behind the bracing strut for the brake linkage to the transmission tunnel (only fitted on RH drive E30s from mid production). Replace this with a hex. headed screw if you ever intend to remove the valve again.
The small bolts holding the valve that are facing the bulkhead are undone from the engine bay by pushing a 1/4 inch socket on an extension bar through the rubber grommet.
It's very unlikely that the matrix needs replacing. They do occasionally fail, but I've never had to change one yet.
Lastly, make sure that your coolant pressure cap has been replaced under the 1997 safety recall. The originals can cause the valve to fail.
