speedo signal
cass1_5503
Post Fri Aug 01, 2014 5:02 pm
im in the process of fitting an alpine sat nav unit and the only wire im having problems with is the speed pulse wire which wire is it at the back of the cluster
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Aug 01, 2014 6:06 pm
On the back of SOME clusters there is a green plug like this:
http://www.e30zone.net/e30zonewiki/inde ... Green_Plug
Any of those pins will provide a speed pulse if you connect a wire to it. If you don't have that plug you can buy one from any of the traders on here, and it simply pushes into the back of your dash cluster.
Post Fri Aug 01, 2014 6:33 pm
Or there's the cheapskate method, which involves pushing the bare end of a wire into the hole where the pin goes (underneath the speedo.), and fixing it in place with a strip of quality adhesive tape.
cass1_5503
Post Sat Aug 02, 2014 11:33 am
thanks guys i do have one of those plugs as my car has cruise control
