Convertible drain holes
snowman
Post Fri Jul 11, 2014 10:14 pm
I have found the dreaded tin worm behind both front wings on my convertible which is not a major problem as I can weld a new piece in and repair it .
My issue is with the drain holes , I know there are two at the botton of the sil behind the wing ,but are there any above these ?.
PG325
Post Sat Jul 12, 2014 9:53 am
The drain holes are easy to spot running along the underneath of the sills, the holes are inside the horseshoe underneath the roof mechanism.
I poked mine with some thick gauge wire and then ran hot water through them, been fine ever since.
