Post
Thu Jul 03, 2014 2:10 pm
The whole of the front is just glued on (the silver part in your picture). Taking care not to cut yourself, you can work your way around the edge with a knife to loosen off the fronts. You can then buy BMW logo replacements, which will come with a sticky backing. Make sure you work out the orientation of the new badges once they are fitted and the centre caps fitted to the wheels. Clean all the old glue off, then you can stick the new fronts on.
