Diff experts, can this be possible ???
E30-Addict
Post Mon Jun 23, 2014 12:39 am
Right
so its an open diff from 320i 3.91 ratio
few weeks back was doing a bit of whining noise
after few burnouts, drifts and high speeds it started acting like a welded or lsd diff
symptoms
1- in burnout, rather than 1 wheel spinning its both
2- turning on full lock, it make noises and one tyre trying to go opposite way
is the diff on its way out or did it get welded on its own lol ?? :mad: :mad: :mad:
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming
HairyScreech
Post Mon Jun 23, 2014 3:04 pm
No but its possible to get a diff so hot that the internals start to bind.
The clearances in them are pretty tight and canning the car at slow speed with no airflow can see a diff so hot that the only way for the gear to expand further is to mash into each other.
Seen it on a sprint car but never a road car so likely a bad sign.
Worth jacking the car up and checking the diff just for safety's sake.
mini-mad
Post Tue Jul 01, 2014 2:39 pm
My mates e36 open diff did that ended up in it losen drive in the middle of no where lol not fun :I.. Ended up that a bit off one of the cog broke off an left it like a welded diff for a couple of weeks untill the rest of the cog went into bits leving him stranded lol..
