Missing and heater dead
mods
Hi i have a bmw 325 cab, car is missing when driving and jerks, changed spark leads and dizy and still no luck. Also heater is gone dead, car has been parked up for one year and all is finewith new battery except the missing problem and no heater, can anyone help with this pls, thanks
mods
Thank u so much for your guidance will check these all today, thanks again
mods
New ignition spark plugs and leads fitted with dizzy cap, still missfires and jerks when u accelerate. Any other things i should trys
TPS
Is the small Starter Motor ring cable attached to the solenoid properly? I had a similar problem, & the 8mm nut had worked loose, & it caused silly faults, like no windows, heater, car wouldn't run great, tightened it up, perfect now.
mods
Will check thanks
