Wiring mess under dash - video
milescook
Post Sat May 31, 2014 6:54 pm
This could be fun! :D
I've actually trimmed out a lot of wiring mess e.g. the old alarm and remote CL, but I'm still left with some mess and empty connectors, plus the CL doesn't work properly (surprise surprise...). Some of these connectors I guess will be speakers.
The odd issue with the Central Locking is when the car is locked, the passenger lock is deadlocked. I can't pull the pin. I have to get in the car, turn the ignition on (to stage 1) and pull the driver's pin. This unlocks the car. I'd certainly like to fix this...
Also interested in:
0:17 Looks like a BMW connector coming from a BMW connector plugged into the accessories socket. Is it supposed to plug somewhere?
1:08 shouldn't this plug into something?
1:14 If it helps, unplugging these stopped the windows working so must be correct.
1:27 what is this - can it be deleted?
2:01 To avoid doubt, this is the green wire that did go to the OBC madness, (badly) joined to where it needs to go so the engine fires up. This was done 2 years ago so I'll go iver it properly one day...
Apologies the wires are sprayed blue 8O Any help appreciated!
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
