overfuelling
squeal
Post Tue Jan 03, 2006 1:47 pm
how do i adjust the fuelling on my 318is,runs fine but if left runnin for a while in my garage smells a bit,any help much appreciated
mrLEE30
Post Tue Jan 03, 2006 1:58 pm
the computer does it for you!
over fueling normally the result of sensors not working correctly especially engine temp (blue) sensor and possibly the thermostat not open/or actually closing properly thus your engine runs too cool. or thinks it is running cool thus adjusts fueling to run richer.
only real adjustment is the AFM but that wont be your problem IMO.
E30Mark
Post Tue Jan 03, 2006 2:00 pm
Fueling at idle is set by the AFM (Airflow meter) get it checked for CO & HC output.
Once off idle the fueling is controlled by the ECU and can't be adjusted. (Not unless you chip the car...)
Chances are it smells, because it's in the garage. When ever my car is garaged it smells 'fumey' but you never smell it when its outside.
PM for details
