316 m10
kevhaggan
hi all just got hold of a m10 316 non runner took thermo off and waterpump and theres 2 bolts snapped and loooks like theyve tried to drill them out but missed what the bst way round this as its overheats to got it for nothing any ideas
Have you got the other bolts out of the waterpump housing yet?
Depends on which bolts have snapped, if theyre right next to each other then it probably wont seal correctly, But if youve got a bolt inbetween the two that have snapped then its worth a go.
These bolts can get really bad corrosion around them due to the ally/water plenty of WD40 is the trick. Or if you can get hold of a blowtorch warm the area the bolts screw into.
HTH
HTH
