hello, Zoners
I need info does engine loom for e30 m20 b25 are all same?
or the other has air conditioning addtional wiring and the other not?
and how to know if it is has air conditioning additional wiring?
Thank you
Markus
e30 m20 b25 engine loom for air conditioning any info?
markus_74
Grrrmachine
- E30 Zone Wiki / Team Member
There are two types. All the Wiring info is here:
http://www.e30zone.net/e30zonewiki/inde ... con#Wiring
markus_74
thank you Grrrmachine.Grrrmachine wrote:There are two types. All the Wiring info is here:
my m40 now have air conditioning, so I think I need only the engine wiring loom that have air conditionig connector?
Grrrmachine
Yes, a standard Motronic 1.3 loom for M20 engines should have the one connector you need, next to the ECU plug.
markus_74
so any e30 m20 engine loom can be used? I mean all m20 engine loom has an extra connector to control the engine speed if the air conditioning turn on, this extra connector is near the ecu plug.Grrrmachine wrote:Yes, a standard Motronic 1.3 loom for M20 engines should have the one connector you need, next to the ECU plug.
is it correct?
or there are 2 different engine loom? with extra connector near the ecu plug and without?
