Strange noise at 120mph+ - HELP!
Stevieabz
I have a 325i Sport Mtech 1 from 1987. It's been remapped, It has a sports manifold and scorpion exhaust. Last night I took her for a midnight drive and everything was fine. I could use all the revs in every gear with no wired noises or any lack of performance. But once I was in 5th and just reaching 117 - 125 a quite loud noise is coming from either the engine or the front left wheel, but I'm really not sure. It's like a grinding sort of weird noise. I did it twice to make sure I wasn't hearing things and it is defo there. Not sure if lack of power comes with it as I didn't let it sound like that for long, or push it harder. The car felt as if it could of gone faster but the noise was putting me off. Any idea's on what this might be or what I should check to maybe find the culprit.
Thanks.
Thanks.
appletree
First thing I would check is if need my licence to get to work in the morning....
Wheel bearing, perhaps? Jack up the car and spin and shake the wheels to check.
gromgsxr
i had a front wheel bearing go bad made a huge amount of noise in the end and a vibration, when i jacked wheel no play at all and could only hear a noise turning it after i removed the wheel and brake ect.
- E30 Zone Meets/Events Team
Where did you manage to clock 120mph ????
I'm sure the GPS would have read lower.
Stevieabz
first: I have no job to get to in the morning, so that's all good there. Second: On a very straight road.. third: I'll check the front wheels today and see if they sound/feel weird.
Thanks.
Thanks.
miniblob
I love how on these threads, everyone acts as though they've never driven above the speed limit!!!
327 Touring with bass!!!
aceifty
I had a grinding noise which got louder as the speed increased, it ended up being the oil drive pully.
If you change the wheel bearings do not got for the cheap crap, I made that mistake once ended up changing it again
1989 cab M20B28 build
aceifty
You can get a good run on the Evesham bypass by the maypole sainsburys.Rav335uk wrote:Where did you manage to clock 120mph ????
I took my r32 skyline there and the m20b28 cab. No speed cameras.
That'll be the Halo effect.miniblob wrote:I love how on these threads, everyone acts as though they've never driven above the speed limit!!!
bigbird76
Is the exhaust all ok ? Surelly at that speed that would get hot.
I have a 535d and its hard to stay within the speed limits on the motorways.
Leigh
Leigh
..Speedtouch wrote:That'll be the Halo effect.miniblob wrote:I love how on these threads, everyone acts as though they've never driven above the speed limit!!!![]()
The Transit don't go more than 80mph
Stevieabz
Guys. It was a loose wheel bolt
But I don't know how that happened.. I made sure each bolt was 100 ft pound, done with a toque wrench and I used copper grease!
Everything else was sound down there, nothing loose or making weird noises but thanks for the help!
I've never owned an E30, this is my third car and I find it hard not to drive it like a race car everywhere. Not that I do! I just find it hard
smithysmith
I'm pretty sure you should be dry torquing wheel bolts.
Jon_Bmw
- Dangerous when thinking
Worrying.
