Anyway the other day at ASDA the starter gave up completely half way through turning over and now won't start at all. Most of the time the starter is whuring but not turning over the engine and the rest of the time it's just not responding at all. Also when the starter is whuring a small puff of smoke seems so come from the + battery strap.
I then began to start troubleshooting in every way that I knew of as I know starters on these cars refuse to fail and it was most probably a wiring issue.
I first checked the earth strap attached to the top of the oil pan. It was corroded slightly but when I by-passed it with a jump cable I still had no response.
Next I checked the battery, I DC'ed it and connected my 325's + and - battery straps to jump cables and hooked them up to my mum's celica battery. While my mum's celica was not running i tried to turn my 325 over and it did turn over but very slowly, not quick enough to start. I then started up the celica and tried my 325 again and it started as it normally would.
So I can safely say that there is either a wiring issue or I have a toasted battery. Although I have a feeling that it's the former.
Im going to take it to my local electronics specialist tomorrow and see what they can find but just knowing that its not a f**ked starter or flywheel means I can sleep easy tonight
Although if anybody has any suggestions that might help it would be much appreciated?
