I have an m20b23 but it's messed up, So I have bought a m20b20 with gearbox. Will the Drive shaft from the b23 fit on the car when I have the b20 with gearbox in it? Or do I have to fit the b23 gearbox on the b20?
I believe the gearboxes used on b23 are Getrag 260 and the gearboxes on b20 Getrag 240?
Drive shaft
- woerie938
Found something on the wiki, The 240 gearbox is longer so i quess the drive shaft won't fit with the 240 box.
But then
question number2, is the clutch interchangable? Cause I will fit in (if it fits) the best one if both engines are out the car.
But then
What's wrong with the M20B23? The M20B20 I gather has the same block and head, it's just the crank that differs, so perhaps you could swap the M20B23 crank into the M20B20...
- **BANNED**
Assume you mean the shaft that runs from the gearbox to the differential?
We call this the 'propshaft'...
Rear part is common to all E30's,front differs with gearbox/engine.
But;
The join between the two halves can be adjusted,so you may get lucky,by sliding the two bits in or out.
But;
Youth is wasted on the young.
- woerie938
It runs on 3 cilinders, I suspect the injectors, And the viscous coupling of the cooling fan is broken. So it became overheated a few times. Lately my radiator started leaking and now I don't have a headgasket anymoreSpeedtouch wrote:What's wrong with the M20B23? The M20B20 I gather has the same block and head, it's just the crank that differs, so perhaps you could swap the M20B23 crank into the M20B20...
But I think I keep some parts of the engine just for spare. I think I keep the crank too so maybe some day I can make a 2300 of it.
Running on 3 may be due to corrosion of the connector underneath the inlet manifold, a common problem.
- woerie938
Yes, I meant the propshaft.daimlerman wrote:Assume you mean the shaft that runs from the gearbox to the differential?
But;
The E30 wiki says it can be adjusted by only 10mm. And the propshaft of a b23 manual is 1468mm and a b20 manual is 1526mm. So that's a difference of 58mm. I don't think it's gonna fit with A b23 propshaft. Or are there any other tricks to make it fit. But I guess I just change the box, It's the cheapest solution since I already have it.
- Brianmoooore
The propshaft is adjustable for length, but it's the rear part that can be changed and the front part that's the wrong length!woerie938 wrote:Yes, I meant the propshaft.daimlerman wrote: The join between the two halves can be adjusted,so you may get lucky,by sliding the two bits in or out.
No connector under the inlet manifold to give problems on a 323i. This plug and socket was only fitted to facelift M20s.
