Flushing the coolant
Cloggy Saint
Post Sun Apr 20, 2014 11:55 pm
Is it simply a case of removing the drain plug on the block and putting a hose over the stub on the inlet side, or is there more to it than that? Thanks.
Post Mon Apr 21, 2014 9:59 am
If you drain a M20 at the block plug and at the radiator, then the only coolant left in the system is that in the heater.
Personally, I like to keep the skin on my knuckles intact, so usually leave the block drain well alone, and just drain the radiator, then flush the rest of the system with clean water.
Refill with the correct total amount of neat antifreeze, and top up with clean water, and the job's done.
Cloggy Saint
Post Mon Apr 21, 2014 1:34 pm
The engine's on a pallet and the block plug is already out, so no skin loss issues. So it's as I outlined in the first post?
Post Mon Apr 21, 2014 1:39 pm
Hell of a lot easier on a pallet! Depending on how fussy previous owners have been about coolant changes and concentration, there mayt be some sludge to flush out.
**BANNED**
Post Mon Apr 21, 2014 1:49 pm
What are your plans for this engine? winkeye
Youth is wasted on the young.
Cloggy Saint
Post Mon Apr 21, 2014 1:54 pm
The plan was to freshen it up and have it fitted about 18 months ago. The reality is freshen it up (done) and then look at it on it's pallet every now and then and come up with excuses not to fit it :(
Cloggy Saint
Post Wed Jun 18, 2014 10:51 am
Digging this up again. To flush the block do I need to attach a hose to the stub at the back of the block or the one on the side?
Post Wed Jun 18, 2014 11:02 am
As it is on a pallet, I would attach the hose to the pipe at the back of the head, it is the highest on the engine and gives you a better shot at flushing all the crap out. Either way, it does not matter too much which orifice you use (must resist !) as long as you end up with clean water coming out.
Cloggy Saint
Post Wed Jun 18, 2014 11:04 am
Ok, thanks, and thanks also for resisting!
