E30 318is lsd possibility?
Jimmy1596
Post Fri Apr 18, 2014 3:19 pm
With the back end and both rear wheels off the ground can spinning and observing the wheels indicate as to whether the 3 series is fitted with an lsd?
DHFiS
Post Fri Apr 18, 2014 6:56 pm
Possibly.
Put car in neutral, both wheels off the ground. If you spin one wheel by hand and the other spins in the same direction it's either an LSD or a welded diff. If you spin one wheel and the other spins the opposite way it's an open diff.
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Apr 18, 2014 7:06 pm
DHFiS wrote:Put car in neutral, both wheels off the ground. If you spin one wheel by hand and the other spins in the same direction it's either an LSD or a welded diff. If you spin one wheel and the other spins the opposite way it's an open diff.
... or knackered LSD needing a rebuilt, like 90% of the LSDs on 25 year old cars.
Simplest method is to look at the metal tag that's on the diff, and see if has a letter "S" on it.
Post Fri Apr 18, 2014 10:37 pm
Only certain way is to take the rear cover off and see what's inside.
Stevevrs
Post Fri Apr 18, 2014 11:21 pm
If the tag is still there ......
Post Sat Apr 19, 2014 3:47 pm
Assuming it is the correct tag.........
