Creaking Noise.
leeuk93
Post Tue Apr 15, 2014 10:31 am
I have noticed a noise that sounds like it is coming from the back drivers side of the car. When I get off from stationary or when turning a corner at slowish speeds I can a creaking noise that sounds like its coming from the suspension or the mounts or somewhere in that region.
I know its hard to diagnose any problems without hearing it etc but I was just wondering if there are any common problems that can occur around that area.
I have a feeling its bushes so going to look into poly bushes asap.
Lee
wullie325i
CAUTION - unreliable trader!
Post Tue Apr 15, 2014 11:17 am
springs around the rubber spring seat area, had this before and it was a broken spring at the lowest point.
can also just be dry rubber try lubricating all the rubber bits in that area to see if it makes a difference
wullie325i
Post Tue Apr 15, 2014 11:19 am
can also try making a straw size hole in any rubber boots if its ball joints ect and fire some oil in to shut it up if thats what it is but its only a temporary fix.
leeuk93
Post Tue Apr 15, 2014 11:36 am
Going to have a proper look into it this weekend, Its just really really annoying.
capnmchl
Post Tue Apr 15, 2014 9:14 pm
My rear top mounts used to creak when I first set off in the mornings, until I replaced them.
