Hello all,
When I lift the lever to adjust the rear/back of the sport seat, it falls all the way down and hits the rear seat unless I hold it, meaning its a two hand operation.
Both the drivers and passenger seats do this and I was just wondering if they should, if not, maybe there is a spring that loses tension?
any help appreciated
Potential Sport Seat Problem
Topblag
I think it'll be the damper that's shot. In my experience it's easier to swap the plates they sit on, piece of cake to do.
Read the wiki.
http://www.e30zone.net/e30zonewiki/inde ... ring_Seats
Read the wiki.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Carmo13
Cheers mate,
So are the seats meant to rise forward and hit your back when you lift the lever, and then you just lean to the position you want and release the lever?
Topblag
Indeed. You should be pushing against pressure to move the seat back towards the rear when the lever is pulled.Carmo13 wrote:Cheers mate,
Carmo13
Ahhh,
yep mine are definitely shot.
Thanks again for the help
